Geoprocessing exception: Workspace is not connected
4330
09-11-2014 07:36 PM
LinaYap1
I am trying to use a GPK file created by ArcMap from ArcGIS Runtime for WPF. But I am getting this exception thrown while trying to execute a task.
"Workspace is not connected". Any clues? Thanks in advance
Edit:
I can actually try executing the task via the service url (using get/post method, fill up the "features" field in JSON, and then do the execution, I get a success message). But when trying to execute task via runtime - it just doesn't work.
MichaelBranscomb
Esri Frequent Contributor
An interesting comparison would be to run Fiddler and compare the request when you call the service via the Rest/HTML endpoint versus calling via the API.
If that does not yield anything, would you be able to post your code and the GPK here?
Cheers
Mike
MichaelBranscomb
Cheers
Mike
LinaYap1
In the end, resolved this -> gave the wrong geometry type (extent instead of a rectangle, was trying to call the tool: Extract By Rectangle, hence...)
The error message is really misleading.
Thanks for the tip too!
