Full Extent button in Navigation toolkit control not working as expected
926
03-15-2013 01:55 PM
GeorgeFaraj
I'm loading a couple of shapefiles into my map. I zoom into the layer and then try to click the Full Extent button, but it only zooms out a little bit, not to full extent. I then click the button one more time and it zooms out a little bit more, and so on until it gets to full extent. Any ideas why this would happen?
MatthewBrown1
I've had the opposite problem and in trying to solve it I noticed that services can have an initial extent and a full extent and often these aren't the same, it's possible that part of your problem comes from one of these values being 'wrong'.
How have you implemented the full extent button? Are you looking at the service properties or the graphics?
GeorgeFaraj
Hey Matthew, I'm using the Navigation toolkit control that already contains a Full Extent button. It seems I don't have a problem when I've loaded my layers through an MPK; it seems loading from a shape file has this problem.
