Error: No imaging component suitable to complete this operation was found.
7548
12
07-26-2011 12:17 PM
MarkCollins
When launching my application today I am receiving the following error. I am loading the ESRI online streets basemap. Everything has worked fine with no change up until today. Is any one else experiencing this error? Any suggestions on the proper way to handle this?
No imaging component suitable to complete this operation was found.    at MS.Internal.HRESULT.Check(Int32 hr)
   at System.Windows.Media.Imaging.BitmapDecoder.SetupDecoderFromUriOrStream(Uri uri, Stream stream, BitmapCacheOption cacheOption, Guid& clsId, Boolean& isOriginalWritable, Stream& uriStream, UnmanagedMemoryStream& unmanagedMemoryStream, SafeFileHandle& safeFilehandle)
   at System.Windows.Media.Imaging.BitmapDecoder.CreateFromUriOrStream(Uri baseUri, Uri uri, Stream stream, BitmapCreateOptions createOptions, BitmapCacheOption cacheOption, RequestCachePolicy uriCachePolicy, Boolean insertInDecoderCache)
   at System.Windows.Media.Imaging.BitmapImage.FinalizeCreation()
   at ESRI.ArcGIS.Client.TiledLayer.tileLoadCompleted(ImageTileInfo data, Stream imgStream, Exception error)
   at ESRI.ArcGIS.Client.TiledLayer.client_DownloadDataCompleted(Object sender, DownloadDataCompletedEventArgs e)
   at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Boolean isSingleParameter)
   at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Boolean isSingleParameter, Delegate catchHandler)
MichaelBranscomb
Esri Frequent Contributor
This error occurs when the tile download fails because the service is not available. Unfortunately, we've not been able to reproduce this error yet.
#. Have you tried registering a handler for the TileLoading event then checking the error property? - does this contain any information?
#. Next time this error occurs it would be great if you could capture the failed tile request and response in Fiddler and post here - or email me on [email protected].
Cheers
Mike
LuisGarcia2
Hi Mike, thanks for your response. No, I have not tried option 1. I will sure try it. As far as Fiddler I will keep it in mind. I can tell you this, the error was pretty consistent in the morning (we are in US central time). In the afternoon, it was still happening for some users in a different city where my company has offices; but not in my location. The other thing is, if I understand you well, the layer was being initialized, but the error happens after that??
Thanks!
DouglasGaston
Mike,
I am also getting this error. I started with a new WPF application and this is all the code that I have added:
<Grid>
        <esri:Map Background="White" WrapAround="True" AllowDrop="True">
            <esri:ArcGISTiledMapServiceLayer Url="http://services.arcgisonline.com/ArcGIS/rest/services/Ocean_Basemap/MapServer"/>
        </esri:Map>
</Grid>
It does not crash all the time, but frequently when I zoom in on an area.
I am transitioning to C# and WPF from C++, so I am not familiar with where the TileLoading event is, or how to register a handler for it.
I don't have Fiddler, but here are the details from my crash:
System.NotSupportedException was unhandled
  HResult=-2146233067
  Message=No imaging component suitable to complete this operation was found.
  Source=PresentationCore
  StackTrace:
       at System.Windows.Media.Imaging.BitmapImage.EndInit()
       at System.Net.WebClient.OnDownloadDataCompleted(DownloadDataCompletedEventArgs e)
       at System.Net.WebClient.DownloadDataOperationCompleted(Object arg)
       at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
       at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
       at System.Windows.Threading.DispatcherOperation.InvokeImpl()
       at System.Windows.Threading.DispatcherOperation.InvokeInSecurityContext(Object state)
       at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
       at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
       at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
       at System.Windows.Threading.DispatcherOperation.Invoke()
       at System.Windows.Threading.Dispatcher.ProcessQueue()
       at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
       at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
       at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
       at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)
       at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
       at MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg)
       at System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame)
       at System.Windows.Threading.Dispatcher.PushFrame(DispatcherFrame frame)
       at System.Windows.Threading.Dispatcher.Run()
       at System.Windows.Application.RunDispatcher(Object ignore)
       at System.Windows.Application.RunInternal(Window window)
       at System.Windows.Application.Run(Window window)
       at System.Windows.Application.Run()
       at WpfApplication2.App.Main() in c:\Users\dgastonadm\Documents\Visual Studio 2012\Projects\WpfApplication2\WpfApplication2\obj\Debug\App.g.cs:line 0
       at System.AppDomain._nExecuteAssembly(RuntimeAssembly assembly, String[] args)
       at System.AppDomain.ExecuteAssembly(String assemblyFile, Evidence assemblySecurity, String[] args)
       at Microsoft.VisualStudio.HostingProcess.HostProc.RunUsersAssembly()
       at System.Threading.ThreadHelper.ThreadStart_Context(Object state)
       at System.Threading.ThreadHelper.ThreadStart()
  InnerException: System.Runtime.InteropServices.COMException
       HResult=-2003292336
       Message=Exception from HRESULT: 0x88982F50
       ErrorCode=-2003292336
       InnerException:
Any help would be appreciated.
Doug
