EmptyMPK_WGS84.mpk in DynamicLayers example application
1210
10-02-2012 06:57 AM
BKuiper
Can somebody explain to me how you can generate the empty MPK as provided in the DynamicLayers example that is hosted on the mainpage of the Runtime website:
http://www.arcgis.com/home/item.html?id=953a530ada30477d95cc69e788268bc9
In other words, how do you add a "Temporary Group Layer" in a MXD. I tried something similar before but couldn't generate a MPK from an empty MXD/Map.
MichaelBranscomb
Esri Frequent Contributor
Empty/blank maps cannot be packaged but you can add a new group layer to the dataframe and then package the map. It's a workaround until we can provide dedicated direct data access via the API in the future.
Cheers
Mike
MichaelBranscomb
Cheers
Mike
BKuiper
Thanks, adding the group layer is the trick is was looking for.
