Deployment Issue
3802
07-08-2012 12:14 PM
rbae
I'm having a problem deploying to a clean Windows 7 machine.
When I run the Deployment Builder, it creates the following path:
C:\TEMP\rbaetest1.0\ArcGISRuntime1.0
In C:\TEMP\rbaetest1.0, I copy the .exe, ESRI.ArcGIS.Client.dll and ESRI.ArcGIS.Client.Local.dll.
When I copy this to the test machine, and try to run the .exe, I get an error message indicating that it cannot load the ArcGIS Runtime deployment - the RuntimeCoreNET.dll.  This dll exists in the rbaetest1.0\ArcGISRuntime1.0\Client64 folder.
Is there something obvious that I'm missing?
-Ryan
KerrieScholefield
On a Windows 64bit machine is possible to receive this error when the application Platform Target of the deployed application is not specified as x64. Try changing the Platform Target to x64 and rebuild the application using similar steps to those below to see if this resolves the issue.
> Open Visual Studio and navigate to the application properties page
> Click the Build tab and change the Platform Target value to x64 in the drop down.
> Rebuild the application and place in the deployment
Alternatively, if your target machine is Windows 32bit  please verify that the application Platform Target is x86 and that you have included the Windows 32bit deployment in your deployment.
Cheers,
Kerrie
rbae
That did the trick.
Thanks Kerrie.
AnkitaBhatia
We have an ArcGIS application developed in arcgis runtime sdk for wpf 1.0.
The test deployment I create for my application runs on a few machines and fails on others. I am not able to identify why!
All the machines are 64-bit and have Windows 7 installed as OS. The RAM available is minimum 4GB.
What could be the issue of the deployment failing on a few machines while running on others.
The error I obtained from log is :
Exception Info: System.Windows.Markup.XamlParseException
Stack:
   at System.Windows.Markup.WpfXamlLoader.Load(System.Xaml.XamlReader, System.Xaml.IXamlObjectWriterFactory, Boolean, System.Object, System.Xaml.XamlObjectWriterSettings, System.Uri)
   at System.Windows.Markup.WpfXamlLoader.LoadBaml(System.Xaml.XamlReader, Boolean, System.Object, System.Xaml.Permissions.XamlAccessLevel, System.Uri)
   at System.Windows.Markup.XamlReader.LoadBaml(System.IO.Stream, System.Windows.Markup.ParserContext, System.Object, Boolean)
   at System.Windows.Application.LoadBamlStreamWithSyncInfo(System.IO.Stream, System.Windows.Markup.ParserContext)
   at System.Windows.Application.LoadComponent(System.Uri, Boolean)
   at System.Windows.Application.DoStartup()
   at System.Windows.Application.<.ctor>b__1(System.Object)
   at System.Windows.Threading.ExceptionWrapper.InternalRealCall(System.Delegate, System.Object, Int32)
   at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(System.Object, System.Delegate, System.Object, Int32, System.Delegate)
   at System.Windows.Threading.DispatcherOperation.InvokeImpl()
   at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
   at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
   at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object)
   at System.Windows.Threading.DispatcherOperation.Invoke()
   at System.Windows.Threading.Dispatcher.ProcessQueue()
   at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr, Int32, IntPtr, IntPtr, Boolean ByRef)
   at MS.Win32.HwndWrapper.WndProc(IntPtr, Int32, IntPtr, IntPtr, Boolean ByRef)
   at MS.Win32.HwndSubclass.DispatcherCallbackOperation(System.Object)
   at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(System.Windows.Threading.DispatcherPriority, System.TimeSpan, System.Delegate, System.Object, Int32)
   at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr, Int32, IntPtr, IntPtr)
   at MS.Win32.UnsafeNativeMethods.DispatchMessage(System.Windows.Interop.MSG ByRef)
   at System.Windows.Threading.Dispatcher.PushFrameImpl(System.Windows.Threading.DispatcherFrame)
   at System.Windows.Application.RunInternal(System.Windows.Window)
   at System.Windows.Application.Run()
