Create map package for disconnected editing
877
02-28-2012 12:05 AM
RobertZargarian
When you create a map package in ArcMap there is a choice you can make
to ???Reference all data??? even if you make a map package from a file geodatabase.
But in the ???Data management tools->Package-> package map??? tool there is not this option.
My question is. Is it possible to create map package from a file geodatabase
with ???Reference all data??? option without using ArcMap GUI?
We want to use the file gdb and package (.mpk) file further in disconnected editing.
If it is not possible to create map package with ???Reference all data??? option
with ???package map??? tool could it be done with ArcObjects programing and run from
ArcGIS server 10.1 as Server Object Extension (SOE)?
Thanks!
MichaelBranscomb
Esri Frequent Contributor
This is a known issue and should be fixed for the final release.
Cheers
Mike
