Connection different graphic layer
1197
05-23-2013 09:29 PM
NandaKumar
I have added 2 graphic layers,On one (layer 1), i am drawing polyline and on other i am drawing (layer 2) some point. I want to know is there any out of box feature to identify the extent of my drawn point of layer 2 in layer 1.
I am using ArcGIS sdk for desktop to do the same.
Thanks in Advance
Nanda Kumar.K
MichaelBranscomb
Esri Frequent Contributor
One (or more) of the geometry operations should help you - perhaps start with GeometryService.RelationAsync() - http://resources.arcgis.com/en/help/runtime-wpf/samples/index.html#/Relation_Online/02q2000000n70000....
Cheers
Mike
NandaKumar
Thanks Mike for the reply,
          I have followed the approach mentioned in the link which you have provided, If i use some Polyline and run my GeometryService.SimplifyAsync() method then it works fine. But if i try creating simple draw point in a graphic layer and tried calling GeometryService.SimplifyAsync() method then in wont get any result (Result will show as 0).
         While calling my relation identify method i have tried like i mentioned below,
GeometryService.RelationAsync(MyDrawPointLayerName.Graphics, e.Results, GeometryRelation.esriGeometryRelationWithin, null), i will
get zero result and if i use,
GeometryService.RelationAsync(MyDrawPointLayerName.Graphics, e.Results, GeometryRelation.esriGeometryRelationIntersection, null), i will get only polyline crossing the Graphic layer.
        Please help me to identify what i am doing wrong.
Thanks in Advance,
Nanda Kumar.K
AnkitaBhatia
Any explanation for this. When we remove the Polyline graphic from the layer it works fine.
I am not sure how the geometry service interprets the graphics and calculates the intersection etc. but would greatly appreciate a small insight so we are able to find the root cause of the above issue.
