Connect ArcGIS API for WPF with MapServer for dummies
1063
09-13-2012 12:44 PM
RomellAvendaño
Greetings community,
Having used the ArcGIS API for WPF component can make a connection to a particular data server whose base is MapServer?
If so, is there a manual or guide for newbies to allow me to make a short and effective test to verify the connection to the map server (MapServer) and viewing .....
Thanks in advance ......
MichaelBranscomb
Esri Frequent Contributor
I'm not sure exactly what kind of test you'd like to run but you I hope you'll be able to find your answer in the conceptual documentation - here's the getting started in Visual Studio topic: http://resources.arcgis.com/en/help/runtime-wpf/concepts/index.html#/Getting_started_with_Visual_Stu....
You can also find the API reference here: http://resources.arcgis.com/en/help/runtime-wpf/apiref/index.html
Cheers
Mike
