Arcgis feature service layers
2694
08-27-2013 10:22 PM
HumzaAkhtar
Hi all,
Does ArcGIS API for WPF allows addition of FeatureServiceLayers on the map? or does it still only supports Feature Layers
Regards
Humz
AnttiKajanus1
Could you define your question in more detail, I think didn't understand it.
HumzaAkhtar
Thanks a lot for your reply.  I have an ARcGIS 10.11 server in which I have MapService layers (Url ending with MapSErver) and FeatureService  layers (url ending with FeatureServer). I wanted to ask that whether ArcGIS api for wpf allows addition of layers whose URl end with FeatureServer directly on to the map? The reason why I ask is that I cannot find any function for initializing feature "services" in the API however there are functions for TiledMap services and DynamicMapServices listed in the API reference.
Thanks
AnttiKajanus1
So you have an FeatureService and you want to add that to map?
You can add those as a FeatureLayers to map like this:
 <esri:Map x:Name="MyMap" Extent="-15000000,2000000,-7000000,8000000" WrapAround="True" Background="#FFE3E3E3">
            <esri:ArcGISTiledMapServiceLayer ID="StreetMapLayer"
                    Url="http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"/>
            <esri:FeatureLayer ID="MyFeatureLayer"
Url="http://services.arcgis.com/1be8I8dpkSL373og/ArcGIS/rest/services/EmissionsInFinland2011_fromExcel/FeatureServer/0"/>
        </esri:Map>
HumzaAkhtar
In the code example that you gave me, you added a Feature Layer which was in that FeatureService, not the whole FeatureService itself. If a FeatureService has multiple FeatureLayers then we will have to add them one by one using XAML tag <esri:FeatureLayer
Thanks
