Zoom Extent doesn't work properly with Feature Layer
2124
07-13-2017 11:33 AM
MuhammadRafay
If feature layers are displayed, zoom extent does not work. I have to press it several times and it zooms out some incremental value each time instead of zooming immediately to the extent of all visible geospatial objects. So I wanted to ask if there is an efficiency strategy built into Esri Feature Layers to avoid loading all objects if they are very far away from the current window? As a result, the 'FullEnvelope' property only encapsulates the currently loaded features. We want it to capture the entire layers window, regardless of what is currently loaded. Is this possible? Following is the code snippet for zoom extent function
override public func zoomExtent() {
        let mutableEnvelope = AGSMutableEnvelope()
        if let esriMap = mapView as? AGSMapView {
            var hasEnvelope = false
            for layer in esriMap.mapLayers {
                if let graphicsLayer = layer as? AGSGraphicsLayer, graphicsLayer.isVisible, graphicsLayer.graphicsCount > 0 {
                    mutableEnvelope.union(with: graphicsLayer.fullEnvelope)
                    hasEnvelope = true
            if !hasEnvelope {
                return
            // Should be done with animation for this
            let _min = CGPoint(x: mutableEnvelope.xmin, y: mutableEnvelope.ymin)
            let _max = CGPoint(x: mutableEnvelope.xmax, y: mutableEnvelope.ymax)
            let bigDiff = max(mutableEnvelope.xmax-mutableEnvelope.xmin, mutableEnvelope.ymax-mutableEnvelope.ymin)
            let padding = max(bigDiff/5.0, 1000.0)
            zoom(min: _min, max: _max, padding: padding, animated: true)
MarkDostal
Thank you for your question!  A FeatureLayer has a "mode" property which specifies how the layer retrieves features from the service.  It is detailed here:  10.2.5: AGSFeatureLayer Class Reference
For your case, you can set the mode to "AGSFeatureLayerModeSnapshot":
In Snapshot mode, the feature layer retrieves all of the features from the associated layer resource and displays them as graphics. This includes all features that satisfy the definitionExpression and defaultDefinitionExpression. Note that the number of features that are retrieved will be limited based on the ArcGIS Server's configuration (500 features by default for ArcGIS Server 9.3, and 1000 for ArcGIS Server 10).
It will be less efficient, because it will retrieve all the features (up to the server limit) instead of only those needed to be displayed, as in the "OnDemand" mode, but it should allow you to get the full extent of all the features retrieved.
Let me know if you have more questions,
Mark
MuhammadRafay
Thank you, that worked.
