Why are geodatabase sync operations so slow?
3680
02-24-2016 12:34 PM
MichaelDavis3
We make extensive use of offline geodatabases in our apps.  It seems like all our sync operations (download replica, sync changes) are very slow to run.  Generally a database with minimal content will take about 90 seconds to 2 minutes to generate on the server.  This doesn't really seem to change until our databases grow to 1-200mb in size, then the wait gets even longer.
What is taking ArcGIS Server so long?
What can we change or optimize in our server configuration to speed things up?
Any plans to improve the performance of these operations in future releases of AGS or the runtime?
GaryMacDougall
Michael
One thing to check are the server logs. You can log at various levels down to debug logging which has the most info. The logs include the time it takes to complete each step of the process - this may help you isolate where the time is being taken.  Is your data versioned or non-versioned + archiving?  do you have attachments?  what release are you on.
thanks
Gary
