Using runtime date fields as a query parameter
5043
01-29-2015 11:46 AM
MichaelDavis3
I was having trouble filtering data from a runtime geodatabase based on date fields (not using a time-aware database).  I finally figured it out:
https://geobits.azurewebsites.net/querying-esri-runtime-database-featuretable-with-datetime-field/
The quick-and-dirty version is that you need to do string comparisons of your date field and whatever NSDate variable you want to compare against, like this:
query.whereClause = [NSString stringWithFormat:@"strftime('%%Y-%%m-%%d %%H:%%M:%%S', DateTime) >= '%@'", [Utility returnStringFromDate:mapViewController.filterDate withDateFormat:@"yyyy-MM-dd 00:00:00 +0000"]];
[Utility returnStringFromDate: withDateFormat:] is just a wrapper for an NSDateFormatter and string conversion function.
-Mike
ForrestKaye
I also have spent a lot of time trying to figure this out.  I haven't tried your solution yet but it looks like it should work.  Exactly what I was looking for. (working on the Android side through) If someone from ESRI is looking at this a sample with a date query would be helpful
