Unable to show feature layer through IOS arcgis runtime sdk
2599
03-17-2017 05:26 AM
DasNobel
I am using below code to show feature layer but it is not showing in ios app. I have created this feature layer through arcgis online.
      //initialize map with basemap
        let map = AGSMap(basemap: AGSBasemap.streetsBasemap())
        //assign map to the map view
        self.mapView.map = map
        //initialize service feature table using url
        let featureTable = AGSServiceFeatureTable(URL: NSURL(string: "https://services7.arcgis.com/JRY73mi2cJ1KeR7T/arcgis/rest/services/NewYorkHospitalLayer/FeatureServe...")!)
        //create a feature layer
        let featureLayer = AGSFeatureLayer(featureTable: featureTable)
        //add the feature layer to the operational layers
        map.operationalLayers.addObject(featureLayer)
Thanks
Tags (1)
DavidLednik
Hi!
You need to specify specific layer inside featureService
let featureTable = AGSServiceFeatureTable(url: URL(string: "https://services7.arcgis.com/JRY73mi2cJ1KeR7T/arcgis/rest/services/NewYorkHospitalLayer/FeatureServe...")!)
regards,
David
DasNobel
Thanks, David. Now I am able to see layer.
Is it possible to show above layer and basemap as an offline mode?
YueWu1
by Esri Regular Contributor
Hi Das,
You can load basemap offline mode by creating a tpk file. For more information please check this:
ArcGIS Local Tiled layer—ArcGIS Runtime SDK for iOS | ArcGIS for Developers
For the featureLayer in offline mode, you need to prepare the data for offline mode, basically enable the sync functions and then you can either choose view-only or editable offline data based on your requirement.
For more information about featureLayer offline, please check: Create an offline map—ArcGIS Runtime SDK for iOS | ArcGIS for Developers
Hope this can help.
Nathan
