Turning off Tile Animation
1459
06-26-2012 05:10 AM
RussellShirley
Hi All,
I have been using the Local Tiled Layer sample as a test bed for designing tile packages. I have found that the animation between the tile levels is distracting if the tiles are all points and lines, especially if layer visibility is different at each level. I found the ???enableTileAnimation??? property in the API reference but can???t find it in the sample.
What am I missing?
Thanks, Russell
DiveshGoyal
You need to cast the object returned by [AGSMapView addMapLayer] to AGSTiledLayerView.
        AGSTiledLayerView* tiledLyrView = (AGSTiledLayerView*) lyrView;
        tiledLyrView.enableTileAnimation = NO;
However, this will turn off all animation  and may compromise UX in other situations (such as panning).
Can you upload a small video capture on YouTube displaying the problem you're seeing? We'd like to understand it more so that we may investigate better ways to improve the UX.
Thanks
AndriyGalushka
is similar property exists in 10.x SDK?
