TOC Sample on/off layer
1080
01-16-2013 12:23 PM
francescodi_vito
Hy guys,
i saw the TOC Sample that i download. When i run the project all layer are ON.
If i would like that all layer are OFF when i open the project?
What is the parameter to be changed?
Help please
Thanks
WadeLobb
Turn all layers off (right click the data frame (often called layers) and turn all layers off)
Save the file (mxd)
next time you open the document all the layers will be off
DiveshGoyal
if you want all layers to be off by default, you can listen for the AGSLayerDidLoadNotification and then set the layer's visible property to NO
francescodi_vito
thanks, but i don't found this method in toc.m
is there any example to see?
thanks
