Some problems I found in using the version of ios SDK
2179
05-29-2013 05:25 AM
lynnwang
Hi all!
     I wrote some demos with the newest version SDK. But there are several problems I cannot resolve.
     1) TextSymbol cannot display the Chinese Characters.
         In the former version ,textsymbol do not have this problem. Now I have to import the font file to the app project,and set the TextSymol font,then the Chinese Charactor can display as a text symbol.
     2)AGSLocationDisplay cannot run in a AGSMapview whose spatial reference is not 4326 or 102100.
        If the spatial reference of AGSMapview is not 4326 or 102100, the app will crash when I use AGSLocationDisplay to display current device location.
      3)AGSPopupsContainerViewController is not stable enough.
        when AGSPopupsContainerViewController is in a callout , I test Popup Sample, I push several AGSPopups into a controller, then swip the pages or tap the PageControl ,the application will crash. But if the AGSPopupsContainerViewController has only one AGSPopus,there is no such problems.
      Are these bugs? or I do not use the SDK properly?
      Thanks.
DiveshGoyal
Hi, Lynn
Thanks for reporting these issues.
I am able to repro #2 and #3. We will try and fix them in the next release.
Can you send me a test project to repro #1. We have tested the text symbol with Chinese strings and it works, so I'd be curious to know what's special about your case.
lynnwang
Hi ,Divesh!
    This is the test project for the repro #1. You can run it in your system.
    Lynn
[ATTACH=CONFIG]24796[/ATTACH][ATTACH=CONFIG]24797[/ATTACH]
DiveshGoyal
Thanks.
Can you also provide the font file you are using the value for the "font family" to get it to work?
lynnwang
    There is something wrong with the upload the attachment. You can download the font file from here:http://pan.baidu.com/share/link?shareid=694289&uk=3489943098
