Selection Box
5075
13
04-18-2012 11:02 AM
AshrafMemon
Hi there,
Has anyone implemented a selection box to define selection envelop for query on the map? The scenario is:
- User clicks on a query button
- users draws a selection box on the map to define query extent
- user clicks search to search the database.
I have implemented step 1 and 3, need some help (examples or pointers) on step 2.
Thank you,
Ashraf
NimeshJarecha
Sorry, i just forgot to mention that you were creating graphic with self.mappoint. Change it to use sketchPolygon. See attached project.
[ATTACH=CONFIG]13653[/ATTACH]
Regards,
Nimesh
NimeshJarecha
Ashraf,
You can use Sketch Graphics Layer for step 2 and pass sketch layer's geometry as query geometry parameter. Look at Sketch Layer Sample.
Hope this helps!
Regards,
Nimesh
AshrafMemon
Hi Nimesh,
How do you create a rectangular box using 2 clicks (or dragging) on the map view? I have been playing with the example you pointed out for the last couple of days to figure out the solution and also playing with the identify example, no luck yet. Can you please send me a some clues of a snippet to resolve the issue?
Ashraf
NimeshJarecha
Ashraf,
You want to create a rectangular box using 2 clicks, that's an envelope. You can't sketch an envelope with sketch graphics layer. You should sketch the polygon and use it in the query geometry parameter.
Regards,
Nimesh
AshrafMemon
Hi Nimesh,
Thank you for your responses.
How about using graphics layer with logic to detect 2nd click below, please assume that the below code is written in the successful if condition to detect second click:
        AGSMutablePolygon* sketchPolygon = [[AGSMutablePolygon alloc] initWithSpatialReference:self.mapView.spatialReference];
        self.mappoint2=mappoint;
        NSLog(@"minx,miny,maxx,maxy:%f,%f,%f,%f",self.mappoint1.x,self.mappoint1.y, self.mappoint2.x,self.mappoint2.y);
        [sketchPolygon addRingToPolygon];
        [sketchPolygon addPointToRing:[AGSPoint pointWithX:self.mappoint1.x y:self.mappoint1.y spatialReference:self.mapView.spatialReference]];
        [sketchPolygon addPointToRing:[AGSPoint pointWithX:self.mappoint2.x y:self.mappoint1.y spatialReference:self.mapView.spatialReference]];
        [sketchPolygon addPointToRing:[AGSPoint pointWithX:self.mappoint2.x y:self.mappoint2.y spatialReference:self.mapView.spatialReference]];
        [sketchPolygon addPointToRing:[AGSPoint pointWithX:self.mappoint1.x y:self.mappoint2.y spatialReference:self.mapView.spatialReference]];
       AGSGraphic *graphic;
        AGSSimpleFillSymbol* myFillSymbol = [AGSSimpleFillSymbol simpleFillSymbol];
        myFillSymbol.color = [UIColor colorWithRed:1 green:0 blue:0 alpha:1];
        graphic = [AGSGraphic graphicWithGeometry:sketchPolygon symbol:myFillSymbol attributes:nil infoTemplateDelegate:nil];
       [self.graphicsLayer addGraphic:graphic];
but nothing shows up on the screen, any suggestions on what I am doing wrong?
Ashraf
NimeshJarecha
Nothing shows up because you are making it invisible.
Change,
To,
myFillSymbol.color = [UIColor colorWithRed:255 green:0 blue:0 alpha:0.5];
Regards,
Nimesh
AshrafMemon
Hi Nimesh,
Sorry that was a mistake, but that didn't solve the problem either. I am attaching the identify demo sample code with the above modification to the code. Can you please check whats wrong?
Thank you,
Ashraf
NimeshJarecha
Just refresh graphics layer after adding the graphic.
[self.graphicsLayer dataChanged]; //add
Regards,
Nimesh
AshrafMemon
just tried that. It didn't work.
Sincerely,
Ashraf Memon
C: 858 405 1484
AshrafMemon
Hi Nimesh,
Is it working on your machine?
Ashraf
