selecting point on map and returning coordinates
1666
07-26-2012 11:27 AM
JeffAli
I'd like to be able to select a point on my mapview and return the latitude and longitude. Does anyone know how this can be accomplished?
Thanks.
NimeshJarecha
Use AGSGeometryEngine's projectGeometry method and project your point to [AGSSpatialReference wgs84SpatialReference].
Regards,
Nimesh
niuruigang
you can by AGSMapViewTouchDelegate's didClickAtPoint method do that as flow:
-(void)mapView:(AGSMapView *) mapView didClickAtPoint:(CGPoint) screen mapPoint:(AGSPoint *)mappoint graphics:(NSDictionary *) graphics
AmilaSilva
Thank you. Using that delegate method I can retrieve the value as map units using the mapPoint:(AGSPoint *)mappoint parameter. But how do I convert it to actual latitude and longitude values?
NimeshJarecha
Regards,
Nimesh
