Route always face up
2352
7
05-15-2019 06:14 AM
tejveer
Set path mode:
The direction that the user should be moving should be facing upward. This is similar to the way that driving apps do it. The map moves as the user moves along the route.
Tags (1)
Nicholas-Furness
Set AGSLocationDisplay.autoPanMode to .navigation.
The location display can be found at AGSMapView.locationDisplay.
tejveer
Hi Nicholas Furness
I have set AGSLocationDisplay.autoPanMode to .navigation but not map moving according to user moved. i have used code given below.
please help me any suggestion. Thanks in advance.
override func viewDidLoad() {
        super.viewDidLoad()
         locationDisplay = self.mapView.locationDisplay
        locationDisplay.autoPanMode = AGSLocationDisplayAutoPanMode.navigation
        locationDisplay.navigationPointHeightFactor = 0.5
        locationDisplay.showAccuracy = true
Nicholas-Furness
Are you starting the location display with AGSLocationDisplay.start(completionHandler)?
Be sure to check for an error in the completionHandler. Note that Apple insist you provide certain keys in your info.plist if you wish to use location. See the note here: ArcGIS Runtime SDK for iOS: AGSLocationDisplay Class Reference
The default location datasource, AGSCLLocationDataSource, needs the app to be authorized in order to access the device's location. The app's Info.plist must contain appropriate purpose strings (NSLocationWhenInUseUsageDescription, NSLocationAlwaysUsageDescription, or NSLocationAlwaysAndWhenInUseUsageDescription keys) to permit this functionality. When the datasource is started it will attempt to request when-in-use authorization if the app's authorization status is not determined, otherwise it will reuse the authorization that has already been granted. If authorization is denied, location updates will not be available.
See also the Display Location sample.
tejveer
Yes
I am using this code in our application..
please check this code.
//Set up location listener and show user's location on map
        locationDisplay.start { (error:Error?) -> Void in
            if let error = error {
                debugPrint(error.localizedDescription)
            self.locationDisplay.locationChangedHandler = self.locationChanged
Nicholas-Furness
Could you provide more details please?
You're seeing the blue dot on the map, and you see the dot moving, but the map isn't orienting itself properly? Perhaps a video or a screenshot would help.
What version of Runtime are you using?
tejveer
W
(view in My Videos)
e are able to seen blue dot as well as moving on the map but not moving map automatically during user navigate. and i have shared video with code snippet given below.please help me. thanks in advance.
        super.viewDidLoad()
Nicholas-Furness
Ah. It looks like you're interacting with the map view. When you do that, the autoPan mode is reset to .off.
You could use the autoPanModeChangeHandler to detect when that happens and either enable a button in your UI (remember to dispatch to main, since the handler could be invoked on any thread), or you could switch the autoPan mode back again (perhaps after a delay). You'll need to think what you want your UX to be.
locationDisplay.autoPanModeChangedHandler = { [weak self] newMode in
    if newMode == .off {
        DispatchQueue.main.asyncAfter(deadline: .now() + 2, execute: {
            self?.mapView.locationDisplay.autoPanMode = .navigation
Or you could just set the interactionOptions appropriately:
mapView.interactionOptions.isPanEnabled = false
mapView.interactionOptions.isRotateEnabled = false‍‍
Again, which option you pick depends on the UX you want for your app.
Hope that helps.
