Question on AGSGDBGeodatabase?
2941
01-28-2014 10:12 PM
c_f_ong
Hello
I've used ArcGIS Desktop 10.2.1 to generate a local geodatabase and added it to my project. Please refer to below for the code I've used to access the geodatabase. However, I've encountered an error as shown below.
    NSArray *paths = NSSearchPathForDirectoriesInDomains(NSDocumentDirectory, NSUserDomainMask, YES);
    NSString *docsPath = [paths objectAtIndex:0];
    NSString *path = [docsPath stringByAppendingPathComponent:@"route_points.geodatabase"];
    NSError *err = nil;
    AGSGDBGeodatabase *gdb = [[AGSGDBGeodatabase alloc] initWithPath:path error:&err];
    NSLog(@"error %@", err.description);
error Error Domain=com.Esri.ArcGIS.ErrorDomain Code=10003 "SELECT ObjectID, Definition, Type FROM GDB_Items WHERE Name = ? collate nocase AND  Type = ?
Any idea what maybe the cause? Any solution?
Thanks.
Rgds
Ong CF
DiveshGoyal
Would you be able to share the geodatabase so that we can investigate?
AndriyGalushka
Hello
    NSError *err = nil;
Thanks.
Rgds
Ong CF
Add you "route_points.geodatabase" in TARGETS/project target/Build Phases/Copy Bundle Resources/
