Project AgsPoint (spatial reference 4326 to spatial reference 102100)
15097
26
10-18-2010 08:52 AM
KOLDODUARTE
Hi all
We need to project the x and y obtained from the ESRI_Places_World/GeocodeServer and show it as a graph into a base map with spatial reference 102100.
We tested with:
AGSPoint *pt = addressCandidate.location;
AGSMutablePoint *newPoint = [AGSMutablePoint pointWithX:pt.x y:pt.y spatialReference:self.mapView.spatialReference];
But this not works.
Do you have any idea?
BR,
Koldo
LucaAlferi1
below formula converts 4326 latitude to 102100 latitude
+ (double)toWebMercatorY:(double)latitude
double rad = latitude * 0.0174532;
double fsin = sin(rad);
double y = 6378137 / 2.0 * log((1.0 + fsin) / (1.0 - fsin));
return y;
below formula converts 4326 longitude to 102100 longitude
+ (double)toWebMercatorX:(double)longitude
double x = longitude * 0.017453292519943 * 6378137;
return x;
See my attachment , it contains a utility mercator convertor . You can simply import the class in your project and call the above static methods on it
I have tried it with location manager and it works!!!
Regards,
Harikant Jammi
Hi Jammi.
I'm a beginner of objective-C. How can use your fantastic code in my code:
- (void)locator:(AGSLocator *)locator operation:(NSOperation *)op didFindLocationsForAddress:(NSArray *)candidates{
    //check and see if we didn't get any results
 if (candidates == nil || [candidates count] == 0){
        //show alert if we didn't get results
        UIAlertView *alert = [[UIAlertView alloc] initWithTitle:@"Informazione" message:@"Nessun risultato trovato" delegate:nil cancelButtonTitle:@"OK" otherButtonTitles:nil];
        [alert show];
        [alert release];
 else {
        //use these to calculate extent of results
        double xmin = DBL_MAX;
        double ymin = DBL_MAX;
        double xmax = -DBL_MAX;
        double ymax = -DBL_MAX;
  //create the callout template, used when the user displays the callout
  self.calloutTemplate = [[[AGSCalloutTemplate alloc]init] autorelease];
        //loop through all candidates/results and add to graphics layer
  for (int i=0; i<[candidates count]; i++){
   AGSAddressCandidate *addressCandidate = (AGSAddressCandidate *)[candidates objectAtIndex:i];
            //get the location from the candidate
            //accumulate the min/max
            if (pt.x  < xmin)
                xmin = pt.x;
            if (pt.x > xmax)
                xmax = pt.x;
            if (pt.y < ymin)
                ymin = pt.y;
            if (pt.y > ymax)
                ymax = pt.y;
 //create a marker symbol to use in our graphic
            AGSPictureMarkerSymbol *marker = [AGSPictureMarkerSymbol pictureMarkerSymbolWithImageNamed:@"BluePushpin.png"];
            marker.xoffset = 9;
            marker.yoffset = -16;
            marker.hotspot = CGPointMake(-9, -11);
            //set the text and detail text based on 'Name' and 'Descr' fields in the attributes
            self.calloutTemplate.titleTemplate = self.searchBar.text;
            //create the graphic
    AGSGraphic *graphic = [[AGSGraphic alloc] initWithGeometry: pt symbol:marker attributes:[[addressCandidate.attributes mutableCopy] autorelease] infoTemplateDelegate:self.calloutTemplate];
            //add the graphic to the graphics layer
   [self.graphicsLayer addGraphic:graphic];
            if ([candidates count] == 1)
                //we have one result, center at that point
                [self.mapView5 centerAtPoint:pt animated:NO];
    // set the width of the callout
    self.mapView5.callout.width = 250;
                //show the callout
                [self.mapView5 showCalloutAtPoint:(AGSPoint *)graphic.geometry forGraphic:graphic animated:YES];
   //release the graphic bb
   [graphic release];
        //if we have more than one result, zoom to the extent of all results
        int nCount = [candidates count];
        if (nCount > 1)
            AGSMutableEnvelope *extent = [AGSMutableEnvelope envelopeWithXmin:xmin ymin:ymin xmax:xmax ymax:ymax spatialReference:self.mapView5.spatialReference];
            [extent expandByFactor:1.5];
   [self.mapView5 zoomToEnvelope:extent animated:YES];
    //since we've added graphics, make sure to redraw
    [self.graphicsLayer dataChanged];
NimeshJarecha
If you want to convert between WGS 1984 (4326) and Web Mercator (102100) then use AGSGeometryGeographicToWebMercator() and AGSGeometryWebMercatorToGeographic() functions.
Regards,
Nimesh
MuruganandhamKuppan1
These methods are not accessible in runtime SDK 100.x. how can i achieve this?
Regards,
Nicholas-Furness
Yes i found that. Lot of stuffs in that class. Thanks Nick.
GregNichols
I had a similar problem, and found a soltuion that might help.    I needed to project a mapPoint from 102100 to other systems using the GeometryService.Project, however this would consistently return a mapPoint with NaN coordinates.   The solution was to first check that the map point is in 102100, if so pass this to the WebMercatorUtil.webMercatorToGeographic to get a latlong mappoint.   Then use the geometry service to project this latlong mapPoint into whatever other coordsystem I needed.   BTW, I'm working with the API for Flex.
-Greg Nichols, TAIC
VijayPatel1
@ harikant_jammi
Thats it...
really working...
Thank you very much.. you save my lots of work...
