Problem with AGSJSONRequestOperation
907
08-23-2011 09:18 AM
EddieJesinsky
Thought I'd point out what may be a problem with AGSJSONRequestOperation (or at least something that should be mentioned in the documentation). Anyway, following the directions on the page http://help.arcgis.com/en/arcgismobile/10.0/apis/iOS/2.0/concepts/00pw/00pw0000004w000000.htm:
I found a quirk with the json that it is capable of returning. It appears that they key "error" is not accepted.
{"error": "The login credentials are not valid."}
returns an error in the api:
2011-08-23 13:02:50.896 LNOSitRep[6324:ec03] -[NSCFString allKeys]: unrecognized selector sent to instance 0x6292700
2011-08-23 13:02:50.899 LNOSitRep[6324:ec03] *** Terminating app due to uncaught exception 'NSInvalidArgumentException', reason: '-[NSCFString allKeys]: unrecognized selector sent to instance 0x6292700'
*** Call stack at first throw:
0   CoreFoundation                      0x01b855a9 __exceptionPreprocess + 185
1   libobjc.A.dylib                     0x01cd9313 objc_exception_throw + 44
2   CoreFoundation                      0x01b870bb -[NSObject(NSObject) doesNotRecognizeSelector:] + 187
3   CoreFoundation                      0x01af6966 ___forwarding___ + 966
4   CoreFoundation                      0x01af6522 _CF_forwarding_prep_0 + 50
5   LNOSitRep                           0x0001fc3a -[AGSJSONRequestOperation processResultData:] + 593
6   LNOSitRep                           0x000215ee -[AGSRequestOperation requestOperationDidFinishLoading:] + 716
7   LNOSitRep                           0x000212d4 -[AGSRequestOperation connectionDidFinishLoading:] + 79
8   Foundation                          0x01581112 -[NSURLConnection(NSURLConnectionReallyInternal) sendDidFinishLoading] + 108
9   Foundation                          0x0158106b _NSURLConnectionDidFinishLoading + 133
10  CFNetwork                           0x0216c48e _ZN19URLConnectionClient23_clientDidFinishLoadingEPNS_26ClientConnectionEventQueueE + 220
11  CFNetwork                           0x022376e1 _ZN19URLConnectionClient26ClientConnectionEventQueue33processAllEventsAndConsumePayloadEP20XConnectionEventInfoI12XClientEvent18XClientEventParamsEl + 293
12  CFNetwork                           0x022379cf _ZN19URLConnectionClient26ClientConnectionEventQueue33processAllEventsAndConsumePayloadEP20XConnectionEventInfoI12XClientEvent18XClientEventParamsEl + 1043
13  CFNetwork                           0x02162c80 _ZN19URLConnectionClient13processEventsEv + 100
14  CFNetwork                           0x02162acf _ZN17MultiplexerSource7performEv + 251
15  CoreFoundation                      0x01b668ff __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__ + 15
16  CoreFoundation                      0x01ac488b __CFRunLoopDoSources0 + 571
17  CoreFoundation                      0x01ac3d86 __CFRunLoopRun + 470
18  CoreFoundation                      0x01ac3840 CFRunLoopRunSpecific + 208
19  CoreFoundation                      0x01ac3761 CFRunLoopRunInMode + 97
20  GraphicsServices                    0x025f41c4 GSEventRunModal + 217
21  GraphicsServices                    0x025f4289 GSEventRun + 115
22  UIKit                               0x00de5c93 UIApplicationMain + 1160
23  LNOSitRep                           0x00002629 main + 121
24  LNOSitRep                           0x000025a5 start + 53
terminate called throwing an exception
I was able to fix it by using the following as my result instead
{"errorMessage": "The login credentials are not valid."}
I just thought that I should mention it, because it seems that using the { "error": "message" } convention may be obvious (and used in other esri REST services). If this is actually a problem on my end please tell me, I'd like to know.
EddieJesinsky
Since I pointed out a potential problem with AGSJSONRequestOperation in my other recent thread http://forums.arcgis.com/threads/40108-AGSAttachmentManager-does-not-properly-handle-secured-service..., I thought I would bump this one too in case it is actually a problem.
