Popup expression is showing empty
951
11-01-2021 08:34 AM
BTDS_GISAdmin
I am using ArcGIS runtime sdk for iOS 100.4. When I show the popup, all the epxression that defined in the ArcGIS Pro for the Map is show blank. How can I fix it? I saw the document on 100.12, there is a method to call before show the popup in iOS. Does it has similar thing in 100.4??
NimeshJarecha
The support to evaluate popup expression started in 100.8. The AGSPopup's evaluateExpressionsWithCompletion: has information, `Since100.8`.
Hope this helps!
Regards,
Nimesh
