pod installation timeout & module not found manually
2276
12-26-2018 08:01 PM
RichardcdcdChuicdcd
I have been frustrating at setting up argis runtime sdf for ios on my xcode. Firstly I use pod to install but after running pod install one minute, it show me "failed to connect to esri.app.box.com port 443 : operation timed out", alright then i switched to install manually, I downloaded arcgis starter app and opened it, i found the bundle file was red (missed), maybe the path is not right. I tried to relocate the file where it install on, but xcode warm me that no such module arcgis. It even try to remove and re-add  the bundle file. The problem still exists. It bloody drive me crazy!! Anybody helps me?
my environment is macOS 10.14.2, xcode 10.1, swift development target 10.0
NimeshJarecha
Hi Richard,
I'm not sure which steps you are following to install SDK using CocoaPods or manually. I would suggest following steps outlined in the Install and set up—ArcGIS Runtime SDK for iOS.
If I follow the steps, I'm not seeing the error `Failed to connect to seri.app.box.com....`. Could you please try again?
Please let me know if you still see an issue.
Hope this helps!
Regards,
Nimesh
