Move marker and Move text
971
09-26-2012 04:12 AM
kartheekpanyam
how to move text from one place to another place using  Arcgis map.
(void) mapView: (AGSMapView *)  mapView didMoveTapAndHoldAtPoint:(CGPoint) screen mapPoint:  (AGSPoint *) mappoint
graphics: (NSDictionary *) graphics
i used this method but Text cant move one place to another place
NimeshJarecha
Is it a text symbol? or label in a map layer? If you are using text symbol for graphic then you'll have to move the geometry to desired location in order to move the text (symbol).
Regards,
Nimesh
kartheekpanyam
Thanks for reply. I used  text symbol. which method i need to use ???
NimeshJarecha
In order to move the location of graphic, you need to set the new geometry to the graphic.
graphic.geometry = newGeometry;
Regards,
Nimesh
