map::at: key not found
1746
10-25-2017 08:32 AM
NikolayYekimov
What is going on here?
ArcGIS`std::__1::map<Esri_runtimecore::HAL::Vertex_attributes::Vertex_element_type, Esri_runtimecore::HAL::Vertex_attributes::Vertex_element, std::__1::less<Esri_runtimecore::HAL::Vertex_attributes::Vertex_element_type>, std::__1::allocator<std::__1::pair<Esri_runtimecore::HAL::Vertex_attributes::Vertex_element_type const, Esri_runtimecore::HAL::Vertex_attributes::Vertex_element> > >::at:
    0x10d27acf0 <+0>:   pushq  %rbp
    0x10d27acf1 <+1>:   movq   %rsp, %rbp
    0x10d27acf4 <+4>:   pushq  %r14
    0x10d27acf6 <+6>:   pushq  %rbx
    0x10d27acf7 <+7>:   subq   $0x10, %rsp
    0x10d27acfb <+11>:  movq   %rsi, %rax
    0x10d27acfe <+14>:  leaq   -0x18(%rbp), %rsi
    0x10d27ad02 <+18>:  movq   %rax, %rdx
    0x10d27ad05 <+21>:  callq  0x10d27b492               ; std::__1::map<Esri_runtimecore::HAL::Vertex_attributes::Vertex_element_type, Esri_runtimecore::HAL::Vertex_attributes::Vertex_element, std::__1::less<Esri_runtimecore::HAL::Vertex_attributes::Vertex_element_type>, std::__1::allocator<std::__1::pair<Esri_runtimecore::HAL::Vertex_attributes::Vertex_element_type const, Esri_runtimecore::HAL::Vertex_attributes::Vertex_element> > >::__find_equal_key(std::__1::__tree_node_base<void*>*&, Esri_runtimecore::HAL::Vertex_attributes::Vertex_element_type const&) const
->  0x10d27ad0a <+26>:  testq  %rax, %rax
    0x10d27ad0d <+29>:  je     0x10d27ad1c               ; <+44>
    0x10d27ad0f <+31>:  addq   $0x28, %rax
    0x10d27ad13 <+35>:  addq   $0x10, %rsp
    0x10d27ad17 <+39>:  popq   %rbx
    0x10d27ad18 <+40>:  popq   %r14
    0x10d27ad1a <+42>:  popq   %rbp
    0x10d27ad1b <+43>:  retq
    0x10d27ad1c <+44>:  movl   $0x10, %edi
    0x10d27ad21 <+49>:  callq  0x10e632b40               ; symbol stub for: __cxa_allocate_exception
    0x10d27ad26 <+54>:  movq   %rax, %rbx
    0x10d27ad29 <+57>:  leaq   0x149043a(%rip), %rsi     ; "map::at:  key not found"
    0x10d27ad30 <+64>:  movq   %rbx, %rdi
    0x10d27ad33 <+67>:  callq  0x10e631e80               ; symbol stub for: std::logic_error::logic_error(char const*)
    0x10d27ad38 <+72>:  movq   0x1ff1af9(%rip), %rax     ; (void *)0x000000010c192ec8: vtable for std::out_of_range
    0x10d27ad3f <+79>:  addq   $0x10, %rax
    0x10d27ad43 <+83>:  movq   %rax, (%rbx)
    0x10d27ad46 <+86>:  movq   0x1ff18ab(%rip), %rsi     ; (void *)0x000000010c192ef0: typeinfo for std::out_of_range
    0x10d27ad4d <+93>:  movq   0x1ff158c(%rip), %rdx     ; (void *)0x000000010c18d894: std::out_of_range::~out_of_range()
    0x10d27ad54 <+100>: movq   %rbx, %rdi
    0x10d27ad57 <+103>: callq  0x10e632b82               ; symbol stub for: __cxa_throw
    0x10d27ad5c <+108>: movq   %rax, %r14
    0x10d27ad5f <+111>: movq   %rbx, %rdi
    0x10d27ad62 <+114>: callq  0x10e632b5e               ; symbol stub for: __cxa_free_exception
    0x10d27ad67 <+119>: movq   %r14, %rdi
    0x10d27ad6a <+122>: callq  0x10e632486               ; symbol stub for: _Unwind_Resume
    0x10d27ad6f <+127>: nop
Tags (1)
MarkDostal
Hello.  In order to better determine what's happening, can you tell me a bit about what you were doing at the time of the error?  Were you displaying a MapView or SceneView?  What kind of data was added to the map?  What operations or map interactions were happening at the time?
Thank you,
Mark
