Invalid operand to binary +
1241
07-14-2010 01:35 PM
AkhlaqRao
I am getting this invalid operand to binary error when I am trying to pass Parcel ID from a text box casted into an integer. Although, I do not need to convert its cast into integer, but I am not sure how can I compare searchBar.text value with "Title_Lookup" fieldAliases?
- (void)searchBarSearchButtonClicked:(UISearchBar *)searchBar
parcelsQuery = [AGSQuery query];
NSString *start = searchBar.text;
int startValue = [start integerValue];
parcelsQuery.where = @"Title_Lookup = '" +startValue+ "'";
parcelsQuery.outFields = [NSArray arrayWithObject:@"*"];
[parcelsQueryTask executeWithQuery:parcelsQuery];
[searchBar resignFirstResponder];
[AGSMapView showNetworkActivityIndicator:YES];
On the other hand this code (below) does not throw any exception nor the results?
parcelsQuery.where = @"Title_Lookup = 'searchBar.text'";
Only this code (below) shows me the result, but I want to pass the Parcel ID dynamically right out of text box casted or without casted..any help will do it.
parcelsQuery.where = @"Title_Lookup = '0022884928'";
Akhlaq Rao
GeoSurfInc.
NimeshJarecha
Try changing your code like this and see if it works..
//int startValue = [start integerValue];
//parcelsQuery.where = @"Title_Lookup = '" +startValue+ "'";
parcelsQuery.where = [@"Title_Lookup=" stringByAppendingString:start];
[parcelsQueryTask executeWithQueryarcelsQuery];
Regards,
Nimesh
AkhlaqRao
Hi Nimesh,
Thanks, yeah I fixed it yesterday. Since I came from .Net and didn't know that I need to buildup the string with format before I pass it as a parameter. I've done almost the same thing as you did the code as follow.
self.parcelsQuery.where = [NSString stringWithFormat:@"Title_Lookup = '%@'", self.parcelsQuery.text = searchBar.text];
[parcelsQueryTask executeWithQuery:self.parcelsQuery];
Regards
Akhlaq Rao
GeoSurfInc.
Regards,
Nimesh
