Increased data usage on 100.12
1361
11-22-2021 11:38 PM
VijayendraKumar
Internet data usage is consuming more on 100.12 version when compared to 100.9.
Prepared a sample app with only few lines of code with changing a map view point on timer basis.
We have taken 20 different locations  on USA(Near Mercer island). And changing view point for every 10 seconds to a new location from those 20 locations.
Attached the both the sample apps. And found 100.12 is consuming 4 times more data than the 100.9 ArcGis version.
Data consumed on 100.9 for 2 hours running of app on iPad: 73 MB
Data consumed on 100.12 for 2 hours running of app on iPad: 260 MB
Note: Proper license key needs to be embedded.
DiveshGoyal
In Update11 we made a change to remove our internal, on-disk cache for tiles to reduce disk I/O operations and improve interactivity/performance on some devices. This cache was redundant as there is already a network cache that iOS maintains. Furthermore, the network cache honors HTTP caching semantics which means that clients can comply with cache settings specified by the tile service. For eg, a service might provide tiles that contain traffic data that should not be cached at all, or beyond a time limit.
Your app may be exhausting the default cache limit that iOS provides. You can try increasing the capacity by changing the sharedURLCache
VijayendraKumar
Thank you for the reply. Actually we don't want to apply URLCache for the entire project. I tried with below code as I am applying for entire project, is there any way to apply only to online ARCGIS api cache mechanism.
  let memoryCapacity = 20 * 1024 * 1024
  let diskCapacity = 300 * 1024 * 1024
  let cache = URLCache(memoryCapacity: memoryCapacity, diskCapacity: diskCapacity)
  URLCache.shared = cache
