improper url causes app to crash
1381
01-15-2013 05:20 AM
HamzaHaroon
When loading services, if the url is not case sensitive for the "MapServer" suffix, my app crashes if it tries to load the service. is there a way to try and catch failed map service load? or catch this error
NimeshJarecha
You should adopt AGSLayerDelegate protocol, set layer's delegate to the class where you adopted the protocol and then try to listen to the methods,  layerDidLoad: and layer:didFailToLoadWithError: to catch whether the layer is loaded successfully or there is any error.
Regards,
Nimesh
HamzaHaroon
i tried :
self.dynamicLayer.delegate = self; (dynamicLayer is of AGSDynamicMapServiceLayer)
and
self.tiledLayer.delegate = self; (AGSTiledMapServiceLayer)
but i get warnings saying incompatible pointer types.
i am adopting the AGSMapViewLayerDelegate, and the AGSLayerDelegate in my class header
HamzaHaroon
it seems my error happens when i try to connect to a mapserver folder that is empty. I get an NSRange exception saying index range 0 out of bounds for empty array
