I need a convenient function within the SDK to enable an app to discover the type of layer dynamically
1622
04-08-2019 10:47 AM
SimonCantrell
I am working on an app using the ArcGIS iOS SDK.
I am reading in Maps from the ArcGIS Online portal. These maps often contain a variety of layers, i.e. Image Layers, FeatureCollections layers, WMS layers, etc. I need a convenient function within the SDK to enable the app to discover the type of layer dynamically, and I then want to go on to operate in various functions on a selected layer, e.g. display its sublayers.
I have been scouring the SDK reference but I cannot determine how to do this yet. Has anyone else managed this?
I did locate the function to determine the portal type: ArcGIS Runtime SDK for iOS: AGSPortalItem Class Reference
However, I want to go down to the next level and determine the type of layer contained within the operational layers after they have been loaded into a map when using an portal identifier to identify the particular map.
I'd like to be able to write the following Swift code:
            var layerType:String!
            //loop over the operational layers and save into an array
           //save the object present in the operational layers array
            let layer = self.layers?[index] as! AGSLayer!
            layerType = layer?.<what can be used to capture the layer type as a string here?>
            if (layerType == "AGSArcGISMapImageLayer") {
                self.mapImageLayer = self.layers?[index] as! AGSArcGISMapImageLayer!
            if (layerType == "AGSFeatureCollectionLayer") {
                self.mapFeatureCollectionLayer = self.layers?[index] as! AGSFeatureCollectionLayer!
            if (layerType == "AGSWMSLayer") {
                self.mapWMSLayer = self.layers?[index] as! AGSWMSLayer!
            if (layerType == "AGSTiledMapServiceLayer") {
                     //Do something else
            if (layerType == "AGSDynamicMapServiceLayer") {
                     //Do something else
            if (layerType == "AGSImageServiceLayer") {
                     //Do something else
etc.
However, unless I'm missing something, when I load all the operational layers in the map into an array of layers, the layer type is not offered in the AGSLayer class.
I can get the name, description, attribution, layerID, extent, etc. but no layer type.
Any help you guys can give will be appreciated.
Thanks!
Tags (1)
RyanOlson1
you can check types of layers like so using swift's as operator, etc:
        let map = AGSMap()
        for case layer as AGSLayer in map.operationalLayers{
            switch layer{
            case let fl as AGSFeatureLayer:
                print("is feature layer")
            case let mil as AGSArcGISMapImageLayer:
                print("is AGSArcGISMapImageLayer")
            // etc...
SimonCantrell
Perfect! That works just fine. Thank you so much.
