Feature Layer Editing
2344
6
09-17-2012 11:14 AM
VIKRANTKRISHNA
The Feature Layer Editing sample shows editing of layers from the webmap. How can do the editing (adding/deletingattributes) in the popup for the layers which are not part of arcgis.com webmap. Specifically, the statement in the method didClickCalloutAccessoryButtonForGraphic()
self.popupVC = [[[AGSpopupsContanerViewController alloc] initWithWebMap:self.webmap forFeature:graphic usingNavigationControllerStsck:NO autorelese];
what do I pass instead of initWithWebMap
NimeshJarecha
You should use NSMutableArray to store your features (one by one) and when you are done with adding all the features, you should use AGSFeatureSet's featureSetWithFeatures to create a feature set and pass the array of features.
Hope this helps!
Regards,
Nimesh
NimeshJarecha
You should do it like this...
AGSPopupInfo *popupInfo = [AGSPopupInfo popupInfoForGraphic:graphic];
AGSPopup *popup = [AGSPopup popupWithGraphic:graphic popupInfo:popupInfo];
self.popupVC = [[[AGSPopupsContainerViewController alloc]initWithPopups:[NSArray arrayWithObject:popup]]autorelease];
Regards,
Nimesh
VIKRANTKRISHNA
Regards,
Nimesh
Thanks!! that works.
Also is it possible to edit a table in the feature service (not related table)?. I need to add records to a table in the feature service based on selection on the map.
NimeshJarecha
Great! Yes, you can add records to the table.
Regards,
Nimesh
NimeshJarecha
If you are satisfied with answer then please mark thread as answered.
Regards,
Nimesh
VIKRANTKRISHNA
Hi Nimesh,
              I have one more question added to this table editing. I am looping through the query results and then creating a new features for table editing (attribute only, no geometry) from query each feature. Then I want to add this new feature one at a time to empty featureSet, how can I do that. I couldn't find a way to add new features to empty featureSet.
Really appreciate help on this.
Vikrant
Regards,
Nimesh
NimeshJarecha
Hope this helps!
Regards,
Nimesh
