ESRI Runtime Error Code 3003
1880
03-15-2020 07:39 PM
ShiminCai
Hi there,
Any idea what has caused this error while generating an offline geodatabase from a feature service? In the sdk guide the code 3003 is Geodatabase Bad XML exception.
Shimin
MichaelDavis3
What is in the feature service?  What did you use to publish?
ShiminCai
Hi Michael,
There are point, line and polygon layers in the feature service. I didn't publish the service but I believe it was published using ArcMap 10.6 or above. The ArcGIS Server is 10.4.1.
Shimin
MichaelDavis3
There is something about this that seems super familiar but having trouble remembering why... is there HTML content in any of the attribute fields?
ShiminCai
Thanks Michael. I did not publish the service. Have passed on the info but haven't got anything back yet. We are also suspecting it might be caused by some data problems...
