Error Syncing Offline Attachment to arcGIS 10.2 in iOS
1948
06-26-2014 12:50 AM
PranovKumar
Hi all,
i am working on a product which requires attachment to be synced to the offline ArcGIS server.
for this i am using the <AGSFeatureLayerEditingDelegate>
//Constructing the AgsFeature Object
agsFeature = [[AGSFeatureLayer alloc] initWithURL:[NSURL URLWithString:url] mode:AGSFeatureLayerModeOnDemand credential:[[DataManager sharedManager] getArcGISCredentials]];
//Assigning the delegate to self
agsFeature.editingDelegate = self;
//Performing the addAttachment
NSOperation *op = [agsFeature addAttachment:attachment.form.uId data:attachment.imageData filename:attachment.name];
but the problem here is that the NSopertion *op is returning 'nil'. and hence the callback to delegate is not happenening.
i am just stuck on it.
Any help suggestion would be of great help..! Thanks.!
DiveshGoyal
Make sure you feature layer (agsFeature) is assigned to a strong property on the VC, otherwise it may get deallocated before the operation completes and the delegate won't be notified.
Here is a doc that describes how you can simplify the code for performing attachment operations on an AGSFeatureLayer using the AGSAttachmentManager class - https://developers.arcgis.com/ios/guide/working-with-the-attachment-manager.htm
DiveshGoyal
