error: property 'calloutDelegate' not found on object of type 'AGSGraphicsLayer'
3863
11-22-2013 10:30 AM
TeresaLewandowski
I am very new to the ios SDK and I am trying to create my first app. I would like to have call outs displayed for my feature layer points (from a feature service). I have been following the developers guide online and consulting the runtime samples provided however I keep running into several errors in the guide and the samples.
For the following sample code:
AGSCalloutTemplate* template = [[AGSCalloutTempate alloc] init] ;
template.titleTemplate = @"${CITY_NAME}"; //show the value for attribute key 'CITY_NAME'
template.detailTemplate = @"${POPULATION}"; //show the value for attribute key 'POPULATION'
AGSGraphicsLayer* layer = ... ;
layer.calloutDelegate = template;
I get the error "property 'calloutDelegate' not found on object of type 'AGSGraphicsLayer'".
and for the following sample code:
- (BOOL) callout:(AGSCallout *)callout willShowForFeature:(id<AGSFeature>)beerLayer layer:(AGSLayer<AGSHitTestable> *)beerLayer mapPoint:(AGSPoint *)mapPoint{
I get the errors "Cannot find protocol declaration for 'AGSFeature' and 'AGSHitTestable'".
How do I rectify these errors?
Cheers
TeresaLewandowski
Yes I have version 10.2 downloaded for the SDK. However after re-reading the documentation I realized that I was working on xcode version 4.6.3. I upgraded my operating system so I could download version 5.0 of xcode. I haven't had a chance to try it out but hopefully that was the issue.
Cheers!
NimeshJarecha
Are you using the latest version (10.2) of the SDK? If not, you should for above codes to work.
Regards,
Nimesh
TeresaLewandowski
Cheers!
Vibin_DhasDevadhason
I have installed ArcGIS 10.1 at initial statge. Also i have installed 10.2 how to configure 10.1 to 10.2 while importing ArcGIS Bundle.  Guide me to move forward..
