Drop Pin rotation issue
2363
5
05-06-2013 12:50 AM
AbhinavGoel
Dear Forum,
Does anybody know how to stop the rotation of the drop pin in the mapview? As this causes problem with the callout. Android SDK does not rotate the pin when the map rotates but it is not there in SDK for iOS.
NimeshJarecha
If you want your graphic not to rotate with map then you should use graphics layer in dynamic mode. Use AGSGraphicsLayer's initWithFullEnvelope:renderingMode method with AGSGraphicsLayerRenderingModeDynamic. This method is available only in the latest SDK (v10.1.1 Update 1).
Hope this helps!
Regards,
Nimesh
NimeshJarecha
Hope this helps!
Regards,
Nimesh
AbhinavGoel
thanks a lot . that worked
adityamehta
hello
I have a related issue. With the AGSGraphicsLayerrenedringModeDynamic I was able to get the PIN to stop rotating but the callout rotates around the pin.
The callout has an offset on the pin graphic, because of which on rotation the callout starts circumferencing the pin graphic.
How can i make the Callout to stay on top of the pin graphic without it rotating.
Thank you
Aditya
NimeshJarecha
Hi Aditya,
Thanks for reporting. We'll try to fix it in the next release.
Regards,
Nimesh
adityamehta
Thanks a lot! it s been fixed now
