Domain Value Change in attribute Editing
3583
11-12-2012 11:45 AM
VIKRANTKRISHNA
When I am changing the Domain  Value from the feature editing popup, its showing me a alert message "Changing Feature Type , you are changing feature type which may potentially overwrite some field values. Are you sure you want to do this". How can I make alert message to not show up.
Vikrant
NimeshJarecha
If you have any default values/domains set for that feature type then that warning message will appear. You cannot disable it.
Regards,
Nimesh
VIKRANTKRISHNA
Just to make in more simple to understand, the FeatureLayer Editing sample also does the same thing (showing alert message) when changing the domain in the popup window.
NimeshJarecha
Regards,
Nimesh
