does Route task API support 9.3.1 Route REST Service
1219
10-23-2011 04:34 PM
RajendraShelar
i want to access 9.3.1 Routing Rest service (i.e. http://myGIS/arcgis/rest/services/RoutingService/NAServer/Route
but using iOS 2 SDK i m getting error after route task execute as below (i m using routing sample code available on resource center.:
There was an error in generation XML document, NSURL = http://myGIS/arcgis/rest/services/RoutingService/NAServer/Route/solve?f=josn
but when i access this url in browser then it is giving following error
{"error":{"code":500,"message":"Object reference not set to an instance of an object.","details":[]}}..
please help asap.
thanks
NimeshJarecha
Yes, ArcGIS Server v9.3.1 Route service is supposed with ArcGIS for iOS SDK? Which version of Apple iOS SDK are you using? Is route service secured? Are you able to execute route task from REST end point in browser?
Regards,
Nimesh
