Crash on Esri_runtimecore::Map_renderer::Seq_shaders_outlined_area::activate_program(std::__1::shared_ptr<Esri_runtimecore::HAL::Device> const&, std::__1::shared_ptr<Esri_runtimecore::Map_renderer::Display_properties> const&, std::__1::shared_ptr<Esri_run
1314
05-22-2017 05:09 AM
AnkitShah
Crashed: com.esri.arcgis.mapRendererQ
0 LAFDBrush_Prod 0x10130a9c4 Esri_runtimecore::Map_renderer::Seq_shaders_outlined_area::activate_program(std::__1::shared_ptr<Esri_runtimecore::HAL::Device> const&, std::__1::shared_ptr<Esri_runtimecore::Map_renderer::Display_properties> const&, std::__1::shared_ptr<Esri_runtimecore::Map_renderer::Sequence> const&, Esri_runtimecore::HAL::Shader_type, Esri_runtimecore::Graphics_abstraction::Texture_sampling_mode) + 1168
1 LAFDBrush_Prod 0x10131191c Esri_runtimecore::Map_renderer::Sequence_draw_visitor::setup_run_(std::__1::shared_ptr<Esri_runtimecore::Map_renderer::Sequence> const&, Esri_runtimecore::HAL::Shader_type) + 384
2 LAFDBrush_Prod 0x1013115cc Esri_runtimecore::Map_renderer::Sequence_draw_visitor::draw_() + 400
3 LAFDBrush_Prod 0x1012fb2c8 Esri_runtimecore::Map_renderer::Graphic_buffer::visit_sequences_(std::__1::shared_ptr<Esri_runtimecore::HAL::Device> const&, std::__1::shared_ptr<Esri_runtimecore::Map_renderer::Sequence_visitor> const&, Esri_runtimecore::Map_renderer::Graphic_buffer::Allow_throttling, bool) + 768
4 LAFDBrush_Prod 0x1012dba88 Esri_runtimecore::Map_renderer::Graphics_layer::draw(std::__1::shared_ptr<Esri_runtimecore::HAL::Device> const&, std::__1::shared_ptr<Esri_runtimecore::Map_renderer::Drawable::Render_properties> const&, std::__1::shared_ptr<Esri_runtimecore::Map_renderer::Display_properties> const&) + 572
5 LAFDBrush_Prod 0x101378858 Esri_runtimecore::Map_renderer::Map::draw(std::__1::shared_ptr<Esri_runtimecore::HAL::Device> const&) + 1092
6 LAFDBrush_Prod 0x100b95c84 Esri_runtimecore::Mapping::Map_view::draw(Esri_runtimecore::Mapping::Device&) + 132
7 LAFDBrush_Prod 0x1007735dc RT_GeoView_draw + 48
8 LAFDBrush_Prod 0x10057ad4c -[RTCGeoView draw:error:] + 148
9 LAFDBrush_Prod 0x100527358 -[AGSGeoViewRenderer doDraw] + 368
10 libdispatch.dylib 0x1881869e0 _dispatch_call_block_and_release + 24
11 libdispatch.dylib 0x1881869a0 _dispatch_client_callout + 16
12 libdispatch.dylib 0x188194ad4 _dispatch_queue_serial_drain + 928
13 libdispatch.dylib 0x18818a2cc _dispatch_queue_invoke + 884
14 libdispatch.dylib 0x188196a50 _dispatch_root_queue_drain + 540
15 libdispatch.dylib 0x1881967d0 _dispatch_worker_thread3 + 124
16 libsystem_pthread.dylib 0x18838f1d0 _pthread_wqthread + 1096
17 libsystem_pthread.dylib 0x18838ed7c start_wqthread + 4
DiveshGoyal
What device was this seen on?
AnkitShah
Hi Divesh, thanks for reply.
Device details as follows
iPad mini 3
iOS version: 10.3.1
4.39 GB Free Space
119 MB Free RAM
