Cocoapods 10.2.5
3288
09-29-2015 05:29 AM
ChristopherMilack1
I'm using cocoapods and as far as I can tell, it has not been updated for the 10.2.5 release. Is that correct? If so, will that be happening soon?
DiveshGoyal
10.2.5 is available through cocoapods (Spec Here : Specs/Specs/ArcGIS-Runtime-SDK-iOS at master · CocoaPods/Specs · GitHub
Try updating your local cocoapods repo using "pod repo update"
DiveshGoyal
ChristopherMilack1
When I couldn't get it to update properly I noticed that cocoapods.org only listed up to 10.2.5 so I assumed it wasn't updates.
I ran that command and set the version to 10.2.5 in the podfile. Worked like a charm.
