Calculating Map Center
3145
03-27-2013 09:08 AM
AaronConnolly
There seem to be 3 ways of calculating the map's center point. Which is the preferred way?
1. Using the center property on AGSMapView?
2. Using the visibleArea method's envelope then, center property?
3. Using the visibleAreaEnvelope's center property?
- Aaron
NimeshJarecha
The center property is CGPoint of AGSMapView and is an inherited property of UIView so that you might not want. There is no center property on visibleArea. There is one on visibleArea.envelope.center, which is same as visibleAreaEnvelope.center.
You should use center property of visibleAreaEnvelope.
Regards,
Nimesh
NimeshJarecha
Regards,
Nimesh
AaronConnolly
Got it. Thanks Nimesh!
