Bug Report: mapview setFrame
696
10-30-2011 10:30 AM
JeremyBixby
When I instantiate an AGSMapView like this:
AGSMapView *mapview = [[AGSMapView alloc] init];
later calling "setFrame" like this:
[_mapView setFrame:CGRectMake(0, 0, self.view.frame.size.width, self.view.frame.size.height - 325)];
produces the following error, when I try to interact with the map object (e.g. autoPan = YES, zoom in/out, or manually pan the map) after I make the setFrame call:
Terminating app due to uncaught exception 'CALayerInvalidGeometry', reason: 'CALayer position contains NaN: [nan nan]'
Instantiating the AGSMapView and setting the frame all at once, on the other hand, produces the correct results:
_mapView = [[AGSMapView alloc] initWithFrame:CGRectMake(0, 0, self.view.frame.size.width, self.view.frame.size.height - 325)];
I can work around it; if it is in fact a bug, I thought you would like to know.
PaulLohr
I am still new to this - maybe it is a chance for me to learn. I could be all wrong on this, Jeremy.
The way I understand how ESRI separates class properties and instance variables is like this:
<mapView> - class property
<_mapView> - instance variable.
This can be seen in the synthesize statement and the header file.
Usually I setup and use the property like this: [self.mapView goDoSomething];
In your example, it looks like you may have alloc/init'd a method variable while you probably also have a class property and instance variable available for use. This assumes you use the ESRI convention of setting up all of these in your header file and synthesize statement.
Paul Lohr
Lohr Geospatial Services, Inc.
