Awry MapService on IOS
2524
07-01-2013 05:07 AM
MariusGächter
Hello everyone
First of all I'm new to the IOS SDK but I already experienced the Android SDK.
I'm doing some tests with the IOS SDK using the same MapServices as I use with Android. On Android everything works just fine but on IOS it looks like so:
[ATTACH=CONFIG]25609[/ATTACH]
whereas on Android like so:
[ATTACH=CONFIG]25610[/ATTACH]
(I know its another building but I think one can see the difference)
I use both FeatureLayer and DynamicLayer.
Has anyone got an idea what this could be? Do I have to make some changes on the services?
Thanks very much for your help.
DiveshGoyal
The maps should look the same on iOS and Android. You do not need to modify the services.
Are you using the same basemap layer in both cases?
Can you list the services you're using?
