ArcGIS iOS SDK Cocoapods - 403 forbidden error
3124
01-05-2021 12:35 AM
AxnMax
I am getting the below error while installing 100.6 version using cocoapods. I am able to install other versions of SDK.
I am getting a 403 Forbidden error for the link https://bintray.com/api/ui/download/esri/arcgis/v100.6-iOS.zip
Below is the error log
-> Installing ArcGIS-Runtime-SDK-iOS (100.6)
> Http download
   $ /usr/bin/curl -f -L -o /var/folders/bx/n0ywspk51nn31rbpsc6rvhdr0000gq/T/d20210105-36811-a3vi8f/file.zip
   https://bintray.com/api/ui/download/esri/arcgis/v100.6-iOS.zip --create-dirs --netrc-optional --retry 2 -A 'CocoaPods/1.10.0.rc.1 cocoapods-downloader/1.4.0'
     % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                    Dload  Upload   Total   Spent    Left  Speed
     0     0    0     0    0     0      0      0 --:--:--  0:00:01 --:--:--     0
     0     0    0     0    0     0      0      0 --:--:--  0:00:03 --:--:--     0
   curl: (22) The requested URL returned error: 403 Forbidden
[!] Error installing ArcGIS-Runtime-SDK-iOS
[!] /usr/bin/curl -f -L -o /var/folders/bx/n0ywspk51nn31rbpsc6rvhdr0000gq/T/d20210105-36811-a3vi8f/file.zip https://bintray.com/api/ui/download/esri/arcgis/v100.6-iOS.zip --create-dirs --netrc-optional --retry 2 -A 'CocoaPods/1.10.0.rc.1 cocoapods-downloader/1.4.0'
MarkBaird
The files on Bintray are no longer available as jFrog have deprecated this service.  You'll be glad to hear that we have already addressed the issue and details can be found here:
https://community.esri.com/t5/arcgis-runtime-sdks-blog/announcement-to-developers-using-cocoapods-wi...
MarkBaird
