App is getting crashed if using .tpk file for offline rendering
775
01-17-2018 03:39 AM
AnkitShah
Please check following crash log from fabric,
Crashed: com.apple.root.default-qos
0 ArcGIS 0x102b927a8 sqlite3VdbeExec.llvm.8B188671 + 968
1 ArcGIS 0x102b92444 sqlite3VdbeExec.llvm.8B188671 + 100
2 ArcGIS 0x102b77a8c ags_sqlite3_step + 572
3 ArcGIS 0x1023b8168 Esri_runtimecore::Geodatabase::Sqlite_command::next() + 56
4 ArcGIS 0x101963fb4 Esri_runtimecore::Mapping::Feature_query_iterator_source::next_() + 136
5 ArcGIS 0x101963e88 Esri_runtimecore::Mapping::Feature_query_iterator_source::Feature_query_iterator_source(std::__1::unique_ptr<Esri_runtimecore::Geodatabase::Cursor, std::__1::default_delete<Esri_runtimecore::Geodatabase::Cursor> >&&, Esri_runtimecore::Mapping::Visitor_ptr<Esri_runtimecore::Mapping::Feature_table const> const&) + 184
6 ArcGIS 0x101964498 Esri_runtimecore::Mapping::Feature_query_result::Feature_query_result(Esri_runtimecore::Mapping::Visitor_ptr<Esri_runtimecore::Mapping::Feature_table const> const&, Esri_runtimecore::Geodatabase::Cursor&&) + 120
7 ArcGIS 0x1019ef92c std::__1::shared_ptr<Esri_runtimecore::Mapping::Feature_query_result> std::__1::shared_ptr<Esri_runtimecore::Mapping::Feature_query_result>::make_shared<Esri_runtimecore::Mapping::Visitor_ptr<Esri_runtimecore::Mapping::Feature_table const> const&, Esri_runtimecore::Geodatabase::Cursor>(Esri_runtimecore::Mapping::Visitor_ptr<Esri_runtimecore::Mapping::Feature_table const> const&&&, Esri_runtimecore::Geodatabase::Cursor&&) + 76
8 ArcGIS 0x1019ef894 Esri_runtimecore::Mapping::Visitor_ptr<Esri_runtimecore::Mapping::Feature_query_result> Esri_runtimecore::Mapping::make_visitor<Esri_runtimecore::Mapping::Feature_query_result, Esri_runtimecore::Mapping::Visitor_ptr<Esri_runtimecore::Mapping::Feature_table const> const&, Esri_runtimecore::Geodatabase::Cursor>(Esri_runtimecore::Mapping::Visitor_ptr<Esri_runtimecore::Mapping::Feature_table const> const&&&, Esri_runtimecore::Geodatabase::Cursor&&) + 28
9 ArcGIS 0x10196c6f8 Esri_runtimecore::Mapping::Feature_table::query_features_local_(Esri_runtimecore::Mapping::Query_parameters const&) + 148
10 ArcGIS 0x10197a9bc std::__1::__function::__func<auto Esri_runtimecore::Mapping::Feature_table::query_features(Esri_runtimecore::Mapping::Query_parameters, Esri_runtimecore::Mapping::Task_options)::$_19::operator()<std::__1::weak_ptr<Esri_runtimecore::Mapping::Visitor_ptr<Esri_runtimecore::Mapping::Feature_table> >, Esri_runtimecore::Mapping::Task_completion_source<Esri_runtimecore::Mapping::Visitor_ptr<Esri_runtimecore::Mapping::Feature_query_result> >, Esri_runtimecore::Mapping::Task_options>(std::__1::weak_ptr<Esri_runtimecore::Mapping::Visitor_ptr<Esri_runtimecore::Mapping::Feature_table> >&, Esri_runtimecore::Mapping::Task_completion_source<Esri_runtimecore::Mapping::Visitor_ptr<Esri_runtimecore::Mapping::Feature_query_result> >&, Esri_runtimecore::Mapping::Task_options&)::'lambda'(), std::__1::allocator<std::__1::allocator>, void ()>::operator()() (.llvm.F947059E) + 88
11 ArcGIS 0x1018ec600 std::__1::__function::__func<Esri_runtimecore::Mapping::Task<void>::Task(std::__1::function<void ()>, Esri_runtimecore::Mapping::Task_options)::'lambda'(), std::__1::allocator<Esri_runtimecore::Mapping::Task<void>::Task(std::__1::function<void ()>, Esri_runtimecore::Mapping::Task_options)::'lambda'()>, boost::any ()>::operator()() + 24
12 ArcGIS 0x101c7723c std::__1::__function::__func<Esri_runtimecore::Mapping::Task_implementation::Task_implementation(std::__1::function<boost::any ()>, Esri_runtimecore::Mapping::Task_options)::$_0, std::__1::allocator<Esri_runtimecore::Mapping::Task_implementation::Task_implementation(std::__1::function<boost::any ()>, Esri_runtimecore::Mapping::Task_options)::$_0>, boost::any ()>::operator()() (.llvm.31DD9986) + 52
13 ArcGIS 0x101c76c28 pplx::details::_PPLTaskHandle<boost::any, pplx::task<boost::any>::_InitialTaskHandle<boost::any, Esri_runtimecore::Mapping::Task_implementation::Task_implementation(std::__1::function<boost::any ()>, Esri_runtimecore::Mapping::Task_options)::$_0, pplx::details::_TypeSelectorNoAsync>, pplx::details::_TaskProcHandle>::invoke() const (.llvm.31DD9986) + 196
14 ArcGIS 0x102ebfe9c pplx::details::_TaskProcHandle::_RunChoreBridge(void*) + 28
15 ArcGIS 0x1027cc8b8 Esri_runtimecore::Common::Core_scheduler::bridge_proc_(void*) + 60
16 ArcGIS 0x1027cc8b8 Esri_runtimecore::Common::Core_scheduler::bridge_proc_(void*) + 60
17 libdispatch.dylib 0x1814529a0 _dispatch_client_callout + 16
18 libdispatch.dylib 0x1814610d4 _dispatch_queue_override_invoke + 644
19 libdispatch.dylib 0x181462a50 _dispatch_root_queue_drain + 540
20 libdispatch.dylib 0x1814627d0 _dispatch_worker_thread3 + 124
21 libsystem_pthread.dylib 0x18165b100 _pthread_wqthread + 1096
22 libsystem_pthread.dylib 0x18165acac start_wqthread + 4
Occured on iOS 10.3.3
