AGSFeatureTable fieldForName returns error if not found
1503
06-01-2020 05:25 PM
MichaelDavis3
Correct me if I'm wrong but the docs for AGSFeatureTable fieldForName indicate that the return value is a nullable AGSField, however if I request a field that does not exist it errors with the following:
ArcGIS Runtime Error Occurred. Set a breakpoint on C++ exceptions to see the original callstack and context for this error:  Error Domain=com.esri.arcgis.runtime.error Code=3017 "The requested field was not found." UserInfo={NSLocalizedFailureReason=platform position is not a field name., NSLocalizedDescription=The requested field was not found., Additional Message=platform position is not a field name.}
C++ breakpoint doesn't return anything helpful.
Docs here:
ArcGIS Runtime SDK for iOS: AGSFeatureTable Class Reference
Shouldn't this return NULL if the field isn't found?  How should I determine if a given field name exists in an AGSFeatureTable without iterating through every field in AGSFeatureTable.fields?
Nicholas-Furness
You can safely ignore the exception. It doesn't propagate up out of the Runtime, it's merely logged to the console (I suspect we should hide that logging - I'll raise this with the team).
The result you get back from the fieldForName() call is still nil, right?
If Xcode is stopping, you should remove any breakpoints on C++ exceptions.
Does that help?
Nick.
Nicholas-Furness
Does that help?
Nick.
MichaelDavis3
Yeah it's only a show stopper if the feature table isn't loaded... which turns out was the larger issue I needed to deal with.  I'm mid-way through upgrading a large and (to me anyway) complex app from 10.x to 100.x so the C++ breakpoints are helping me catch all the spots where I missed bits in the initial flurry of finding and replacing.
