StandardOfflineLicencing returning error 400 invalid redirect_uri
2372
6
06-07-2017 11:47 PM
KestutisKaladinskas
Hello Team,
I am following the below link to remove "Licenced for debveloper use only" from my mapview using standard licencing:
https://github.com/FernandaOchoa/Arcgis-Samples-Android-SDK/blob/master/StandardLicenseOffline/src/m...
I am using portal url of my app.
Outhview showing the error 400 invalid Redirect_Uri.
Please suggest?
AlexanderNohe1
Honored Contributor
Did you specify a valid redirect uri in the online developer console?
ArcGIS for Developers
It is a whitelisted system, so any redirect uris that you use need to be listed there.
KestutisKaladinskas
Thanks Alexander,
I am passing correct uri now but after passing the uri, the outh view is showing white screen.
None of the UserCredential callback method is calling.
AlexanderNohe1
Honored Contributor
Are you working with an embedded webview or are you working with a browser?
Are you able to reproduce the problem with this sample:
developer-support/runtime-android/authenticate-with-oauth at master · Esri/developer-support · GitHu...
KestutisKaladinskas
I am using OuthView and arcgis library version 10.2.8-1.
and your above example using version 100.0.0 and i am not able to update the arcgis library in my code becouse in new library, almost all classes are changed.
AlexanderNohe1
Honored Contributor
As a test, could you try running this to see if it works?
This could help narrow down where you may be running into trouble and will make overall troubleshooting easier in the long run
KestutisKaladinskas
Thanks for suggestion Alexander, Right now outhview is showing blank screen and usercredentials callback method is not calling, but watermark is disappeared. It is strange so i am calling outhview but not showing the outhview inside my layout and  this way my problem get resolved.
