Removing callout's extra white space on Android
2560
07-30-2020 08:51 AM
HristijanPetrovski
Hello esri community,
I'm trying to show a callout that needs to be in the same callout window except without the extra white space that I've marked with red.
My implementation is the following
<?xml version="1.0" encoding="utf-8"?>
<resources>
    <calloutStyle
        borderWidth="0"
        cornerRadius="20"
        leaderLength="10"
        padding = "0"
        margin = "0"
        leaderPosition="LOWER_MIDDLE"
        leaderWidth="20" />
</resources>
<LinearLayout
    android:layout_height="wrap_content"
    android:layout_width="wrap_content"
    android:orientation="vertical"
    xmlns:android="http://schemas.android.com/apk/res/android">
    <com.google.android.material.textview.MaterialTextView
        android:background="@drawable/title_layout_bg"
        android:backgroundTint="@color/colorPrimary"
        android:id="@+id/title"
        android:layout_width="250dp"
        android:padding="10dp"
        android:textSize="18sp"
        android:textColor="@android:color/white" />
        android:id="@+id/description"
        android:layout_marginTop="8dp"
        android:layout_width="match_parent"
        android:maxLines="2"/>
        android:layout_gravity="end"
        android:id="@+id/readMore"
        android:layout_marginBottom="8dp"
        android:layout_marginEnd="16dp"
        android:padding="5dp"
        android:text="@string/read_more" />
</LinearLayout>
No matter what I do there's always extra white space around the view.
Any help?
AlanLucas
Hi Hristijan,
The Callout includes padding equal to the Corner Radius. Reducing the Corner Radius will reduce the empty space.
Hope that helps, Alan
HristijanPetrovski
The design requirement has a cornered radius but i don't need the extra space.
HristijanPetrovski
If i reduce the corner radius to 0 and my view is rounded, the edges that are sharp (not rounded) will be visible since they're drawn behind my custom content layout...
