Need feature layers with different spatial references
1493
03-17-2020 09:15 AM
DevendraKhatri
This is my requirement-
Feature layer with different Spatial References with offline capability.
I tried searching online I did not find any. Later, I thought I will create feature layer from portal giving different spatial reference. To get different spatial references I referred this URL: https://services9.arcgis.com/6YbKjnvgB8zdSTlq/arcgis/rest/services/bangalore_test/FeatureServer
I used some of the spatial references form projected and geographic coordinate system. Some of the wkid were showing invalid and whichever worked [ 2000 ] gave me some unexpected result in my app while loading the geodatabase of the same layer.
- while doing this geodatabaseFeatureLayer.selectFeaturesAsync , I see feature.getGeometry() returns null but feature.getFeatureTable().hasGeometry() returns me true.[ Android ArcGIS sdk 100.5.0 ]
Is there any difference here !.
Help me - provide some layers with SR different from 3857 and 4326 or how I can create my own with the available coordinate systems provided.
Thanks
GayleYoung
Hi Devendra, I tried going to the URL you provided. If you look at the Fields listed in https://services9.arcgis.com/6YbKjnvgB8zdSTlq/ArcGIS/rest/services/bangalore_test/FeatureServer/0 then you will see there is no geometry field for the features; these have a field type of esriFieldTypeShape.
DevendraKhatri
My bad. Sorry.
I was mentioning this URL to refer various coordinate systems
Using spatial references—ArcGIS REST API: Services Directory | ArcGIS for Developers
