Mapview and Sceneview
1059
07-28-2021 06:04 PM
Gharding
Dear ESRI,
I'd like to have a full
screen mapview and a full screen
sceneview and use a button to
switch between the views.
Can you help me with the
xml layout file and the ESRI
code to switch between the
2D and the 3D view?
Thank you.
Jack
[email protected]
RamaChintapalli
This sample can be a starting point to achieve what you are looking for and build on top of it to enable or disable the views.
https://developers.arcgis.com/android/java/sample-code/sync-map-and-scene-viewpoints/
Rama
