Make a pulse animation PictureMarkerSymbol in android
2086
07-19-2017 11:58 PM
chiragshah4
I need to make pulse animation with hight and width. Is it possible in android PictureMarkerSymbol?
AlexanderNohe1
Honored Contributor
Found some time to write the sample...
Check out this pull request on our developer-support site:
Pulse Graphic Sample in Kotlin by nohe427 · Pull Request #309 · Esri/developer-support · GitHub
AlexanderNohe1
Honored Contributor
Should be possible.  I see that you have the iOS code available to you as well.  I believe you would need to user the Timer class:  https://developer.android.com/reference/java/util/Timer.html#scheduleAtFixedRate(java.util.TimerTask, long, long)
If I get a chance later today, I will try to come up with a quick sample.  We have been pretty busy over here with the new releases lately so I have not been able to produce as many samples.
AlexanderNohe1
Honored Contributor
